need help with trunk latch - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: The Basics (//www.focuscanada.net/forum/forumdisplay.php?fid=25) +--- Thread: need help with trunk latch (/showthread.php?tid=21300) |
need help with trunk latch - X TUH BOARD - 06-27-2013 When I press the trunk release in my 07 sedan it sounds like a machine gun going off. it open but takes a few attempts to close.. If I disconnect the power the key works fine. This is my wife car and she didn't like the key only solution i gave her.. Is there a cheap fix or do I have to go to the dealer for a new latch? RE: need help with trunk latch - ZTWsquared - 06-27-2013 Hard to close trunk = common problem - sounds like the latch needs adjusting. (06-27-2013, 08:48 PM)X TUH BOARD Wrote: When I press the trunk release in my 07 sedan it sounds like a machine gun going off. it open but takes a few attempts to close.. If I disconnect the power the key works fine. RE: need help with trunk latch - X TUH BOARD - 06-28-2013 it's not hard to close..I think the latch is tripping out and staying in the open position..I have to press the trunk button 2 or 3 times before it locks.. RE: need help with trunk latch - drunkinmonkey - 07-03-2013 lube the pos up!!! need help with trunk latch - GFXjamie - 07-03-2013 All doors need lube or will start sticking I learned this a couple years ago lol RE: need help with trunk latch - Oscar The Grouch - 07-03-2013 take the latch out of the assembly, bring it to a local locksmith, they'll take it apart, clean it and lube it up. cost me bout 30 bucks to do but worth it. |
