Timing belt
My phones dying and I'm going to get straight to the point
Worth it do it yourself? Time and tools required? Cost if had someone else do it? Putting cam gears in at same time?
red 00' zx3 daily driven
I have a little stock pile building of extra parts building, MSG if you need anything
I did mine myself in my drive way....took a weekend, ull need a metal plate sorta thing to keep the cams from turning once the belt off, other then that theres no other special tools ull need...do the water pump while your in there. as for worth getting a shop to do it....it'll be expensive....if your capable do it your self...just dont f*ck up the timing!Big Grin
most cams come with a timing tool , if not massive speed systems sells them and it works awesome
The only part that sucks about doing timing yourself and swapping the cam gears is holding the cams and cam gears solid while trying to torque the camgear bolts. Which also you should replace with arp... I stripped 2 stock sets of camgear bolts trying to torque them down
...because RACECAR! haha
If you want I can do it for you I work out of my garage on the weekends
  2004 SVT Timing Belt Replacement Eddz4 2 1,855 07-27-2013, 10:53 AM
Last Post: NoiSeeVT
  Timing belt replacement Lucster1000 6 2,792 05-24-2013, 10:31 PM
Last Post: drunkinmonkey
Question Timing Belt Change heelchain 17 8,897 03-17-2013, 11:13 PM
Last Post: heelchain
  Timing belt problems! stupica1 7 3,623 09-11-2012, 11:40 PM
Last Post: stupica1
  Timing or Cam Belt ?? pavlito24 3 1,857 08-15-2011, 09:52 AM
Last Post: Focus man. Focus.
  Timing Belt or Timing Chain dragerboat 2 2,429 05-07-2010, 10:07 PM
Last Post: dragerboat
  When To Replace Timing Belt? Just4Derek 3 1,806 01-06-2007, 07:04 AM
Last Post: ANTHONYD
  Timing Belt dannyq 5 2,114 07-24-2006, 01:45 AM
Last Post: NOS2Go4Me
  Timing Belt 01-yellow-ZX3 17 7,364 03-28-2005, 12:46 PM
Last Post: 2001 ZTS
  Timing Belt Wearing Funny? rubberman 13 3,994 03-23-2005, 03:13 AM
Last Post: 01-yellow-ZX3
