Egr Valve Stuck..? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: Egr Valve Stuck..? (/showthread.php?tid=1223) |
Egr Valve Stuck..? - konafocuswrc - 07-03-2009 what happens when EGR valve stuck?? i thought it was DPFE sensor problem but same stumble hesitation symptom came back.. what happens when EGR valve.. stuck open?? and stuck closed?? or could this be fuel filter?? Egr Valve Stuck..? - Mason - 07-03-2009 Could be fuel filter or a few other things. Has the car givin u a MIL regarding the EGR valve. Usually if its stuck you get a code right away. Check PCV valve aswell. Its known to cause a stumble at idle. And follow the hose that goes from the PCV to the rear of the motor. Alotta times the elbow in that hose is collapsed and will cause vacuum related issues. Egr Valve Stuck..? - konafocuswrc - 07-03-2009 oh that, pcv hose, replaced 2 months ago.. that fixed stalling problem when hard braking.. i found something weird, it could be my intake.. car was stumbling at idle, popped hood and wiggled intake and rpm went normal.. but could be coincident.. Egr Valve Stuck..? - Mason - 07-03-2009 Have you tried cleaning the intake aswell as the mass airflow sensor? When was the last time u actually did the fuel filter? lol If the intake was loose or cracked you moving it could have sealed a small leak. U should inspect it Egr Valve Stuck..? - NOS2Go4Me - 07-03-2009 The wiring harness for the MAF could be cracked / bare wires / overstretched as well. That was an issue with the SPI, too. Check the wires right where they run into the MAF sensor itself. Egr Valve Stuck..? - konafocuswrc - 07-04-2009 i cleaned maf and intake and didn\t change anything.. maybe i put too much oil treatment after cleaning.. because when i start my car and put hand on intake opening, there is not much suction until i do wot.. or intake base is made out of rubber, instead of metal, that might be aged and torn somewhere through metal clamp.. i gotta try fuel filter too, it is not that expensive, so i m gonna give it a shot.. maf sensor itself might be fine, ford told me maf is reading but weird.. Egr Valve Stuck..? - Mason - 07-04-2009 If you got cleaning oil in there it would pull through and burn clean after a day or 2 Egr Valve Stuck..? - konafocuswrc - 07-04-2009 not cleaning oil, treatment oil.. it is sticky gooey stuff you spray onto filter after cleaning.. Egr Valve Stuck..? - Focus man. Focus. - 07-04-2009 I think you need to take a step back for a minute. You keep throwing money at your car replacing 1 or 2 pieces at a time attempting to diagnose one of many problems. Maybe, just maybe try taking it in, somewhere and have them find the issue and fix it. It will probably be a bit of coin to have that done but in the end you wont be replacing everything 1 piece at a time. Just a thought. May or may not work for you, just a suggestion. Egr Valve Stuck..? - Mason - 07-04-2009 Focus man, Focus.,Jul 3 2009, 07:44 PM Wrote:I think you need to take a step back for a minute. You keep throwing money at your car replacing 1 or 2 pieces at a time attempting to diagnose one of many problems. Maybe, just maybe try taking it in, somewhere and have them find the issue and fix it. It will probably be a bit of coin to have that done but in the end you wont be replacing everything 1 piece at a time. Just a thought. May or may not work for you, just a suggestion. Well what is the diff if you do it and it costs u a little or you pay them to do the same thing ant itcosts u more. With out an engine light chase a problem is all you can do. And out side of talk about normal things that he should be doing anyway or things to look at that wont cost him anything but a little of his time I havnt seen him toss money at anything. ;) Anyway if your sure the problem got better when you moved the intake around check the hoses off the intake and the tube for damage or cracks. While you have it off take a good look at the intake manifold, and the hose for the air breather. Uhhh other then that I cant think of anything eles. let me know how it looks :lol: Egr Valve Stuck..? - ZTWsquared - 07-04-2009 Mason,Jul 4 2009, 12:46 AM Wrote:Focus man, Focus.,Jul 3 2009, 07:44 PM Wrote:I think you need to take a step back for a minute.ÃÂ You keep throwing money at your car replacing 1 or 2 pieces at a time attempting to diagnose one of many problems.ÃÂ Maybe, just maybe try taking it in, somewhere and have them find the issue and fix it.ÃÂ It will probably be a bit of coin to have that done but in the end you wont be replacing everything 1 piece at a time.ÃÂ Just a thought.ÃÂ May or may not work for you, just a suggestion. Well he's already replaced the DPFE which turned out not to be the problem ... and now he's thinking of replacing the EGR. If you buy those two pieces at a Canadian dealer they'll run you 360 bucks with taxes. OTH - my dealer charges 50 to diagnose a problem (zero if they fix it) and there might be some shops that would do it for a lot less. I agree - first check those things that only take your time to do it ... but there's also the issue of expertise here (no offense Kona) - and in terms of diagnosing a problem like this there is no amount of time or effort that will replace it. If it were me, I would have checked everything I knew to check first without replacing components ... and if I couldn't figure it out at that point I wouldn't screw around with it ... I'd pay an expert to tell me what the problem was. Just my .02 FWIW. Egr Valve Stuck..? - konafocuswrc - 07-05-2009 nope i didn't replace dpfe, i said i did hack on it..using golf tee and shove it in.. and i was thinking egr valve too and used valve cap to keep exhaust coming out because i thought my intake sucks in exhaust.. and i narrowed down to intake leaks.. when i had ford to replace fuel pump assy under recall, they tested and diagnosed already and couldn't find anything.. so i didn't waste my money on anything yet.. Egr Valve Stuck..? - Flofocus - 07-09-2009 Did you check the wires going into the coilpack? Mine were starting to frey and caused some major stumbling for me. check this out... http://www.focuscanada.net/forum/index.php...57&hl=coil+pack |
