Need Help! Cf Hood Install......? - Printable Version
+--- Thread: Need Help! Cf Hood Install......? (/showthread.php?tid=14352)
Need Help! Cf Hood Install......? - SL8RZZX3 - 07-05-2005
For some reason i can't get the hood latch to lock into the second lock of the hood lock........?
any help or pointers?
pics will follow as soon as i can get it to fit..........
Need Help! Cf Hood Install......? - S2 - 07-05-2005
I had that happen but it had to do with my hood release cable and I had to get it replaced. I highly doubt that is your problem though since obviously it just worked before you took the stock hood off and it's way to coincidental for it to happen.
Make sure there is no crud in the locking mechanism as well, make sure you back down the bump stops (rubber bumpers) in the engine bay that the hood rests on as maybe the design of the CF hood is slightly different (support structure) that the rubber bumps sit on. Just a thought.......
Yeah it was the rubber bumps on the frame :angry:
and i still have to slam it shut :angry: But it closes and thats what counts :D
picks will come when i get my hands on a camera
Need Help! Cf Hood Install......? - NOS2Go4Me - 07-05-2005
You should be able to raise / lower those by turning them clockwise / counterclockwise like the trunk / hatch bumpers, Gord.
Right on, looking forward to the pics!!! Which CF hood do you have?
Need Help! Cf Hood Install......? - ANTHONYD - 07-05-2005
:postpics:
ANTHONYD,Jul 4 2005, 04:13 PM Wrote::postpics:
[right][snapback]119230[/snapback][/right]
I know I know, but my camera is on vacation with my folks, but i swear i'll get pics soon! even if i have to go get a disposable ( they make disposable digitals don't they?)
Oh and it's the VIS CF invader hood :lol: :lol: :lol:
NOS2Go4Me,Jul 4 2005, 02:38 PM Wrote:You should be able to raise / lower those by turning them clockwise / counterclockwise like the trunk / hatch bumpers, Gord.
[right][snapback]119221[/snapback][/right]
i had 'em all the way down and it still wouldn't close :angry:
so now they're out! :D
Need Help! Cf Hood Install......? - schade - 07-05-2005
just notch a hole in the hood so it clears the bump stops ;)
Need Help! Cf Hood Install......? - ZX3TUNING - 07-05-2005
open up the hood and look at how the latch is dropping into the catch. if the latch is shifted to one side, check the alignment of the hood. if the hood is even on all sides, put the hood up, remove the grill and rad cover, get a 8mm wrench in there and loosen off the catch bolts and shift it in the direction of the latch arm. sung down and lower the hood and check spaces. if you still need to move the catch over more, unbolt it completely and file the holes to an oval shape, replace the catch and retest. this is common with most aftermarket hoods even OEM replacement metal hoods, they all need to be fit propperly as each one is slightly different.
and please, put the rubber bumpers back in or the catch will eventually break from the hood fluttering at speed.
good luck and post pics!
