Hvac Control Problems - Printable Version
+--- Thread: Hvac Control Problems (/showthread.php?tid=16066)
Hvac Control Problems - ZX3 in progress - 02-07-2005
The other night I went to start my car before I came to work and when I moved the fan control to turn it up it was a little stuck. I just used a bit of force but not much and turned it up. Well I noticed then that it wouldn't work on any of the setting 1-4. Now it only works when it is between 3-4 at a certain point but only comes out at one speed and it's not a fast one. Anyone know what this could be??
Hvac Control Problems - Zoom - 02-07-2005
Undo the entire console and check if you maybe loosened the connection on the back. Other than that go to ford.
Hvac Control Problems - ZX3TUNR - 02-07-2005
I had same prob. Was a loose connection from when I was messing around with things. Maybe you have the same prob. Lets hope.
Thanks guys I'll try that when I get home in the morning since I'm finally done my week of midnights. I hope this is the problem too
