European Mirror Install - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: How To's (//www.focuscanada.net/forum/forumdisplay.php?fid=24) +--- Thread: European Mirror Install (/showthread.php?tid=17745) |
European Mirror Install - guilty - 04-09-2004 Tools needed: 10mm socket T-20 torx driver Process: 1. Unscrew mirror adjustment knob (turn counter clockwise) 2. Remove plastic cover from door, attached with plastic/metal clips. First from the front of the car, then two clips towards the rear. 3. Remove torx screw 4. Remove 10mm bolt from access hole. (don't drop it inside the door!) 5. Pull mirror away from door, feeding the adjusting cable assembly through access hole Pics: Removing panel: Access to bolts: <a href='http://img32.photobucket.com/albums/v96/guilty/Mirror%20How-to/Picture_003.jpg'> ![]() Installed mirror: Finished product: <a href='http://img32.photobucket.com/albums/v96/guilty/Mirror%20How-to/Picture_015.jpg'> ![]() Replace with new mirror, repeat steps in opposite order. Insert painted cover into mirror by snapping on from bottom to top. Note: European mirrors omit the torx screw. European manual mirror adustment knobs are NOT compatible with North American knobs. I need to pick up the new part.. European Mirror Install - xappie - 04-09-2004 NICE! I really like those mirrors. Where'd you get them??? European Mirror Install - Bort - 04-09-2004 Steve your car is looking sweeter all the time! I bet Jay's gettin jealous :) European Mirror Install - guilty - 04-10-2004 xappie,Apr 8 2004, 10:55 PM Wrote:NICE! I really like those mirrors. Where'd you get them???I got them from www.bosseuroparts.com, definitely 100% recommendation coming from me. And thanks for the compliment Jason.. you should come by work this weekend to check out the new spoiler. European Mirror Install - lordkingod - 04-10-2004 Very good how-to ;) European Mirror Install - Bort - 04-10-2004 Steve, u working Friday, or you got the day off cuz of the stat? European Mirror Install - ZX3 Canuck - 04-10-2004 guilty,Apr 8 2004, 08:06 PM Wrote:European manual mirror adustment knobs are NOT compatible with North American knobs.Huh? The stock manual knobs on my car worked fine with the manual european Ford mirrors when I installed them on my car a couple years ago. |
