How do I ... - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: The Basics (//www.focuscanada.net/forum/forumdisplay.php?fid=25) +--- Thread: How do I ... (/showthread.php?tid=19172) |
How do I ... - ZTWsquared - 06-15-2011 ... install these fricken H7 bulbs in my MACH headlight assemblies. H7 bulb connector ![]() This is what the mounting point looks like (shouldn't there be a wire clip attached to one of these screws?) ![]() This is bulb connector with metal clip attached ![]() And this is the metal clip removed from the bulb connector. ![]() RE: How do I ... - GFXjamie - 06-15-2011 Are those for the high beams? Because i know low beams are d2s RE: How do I ... - ZTWsquared - 06-15-2011 (06-15-2011, 11:08 AM)GFXjamie Wrote: Are those for the high beams? Because i know low beams are d2s Yeah no problem with the low beams (and yes D2S) ... H7s are indeed high beams and buried to one side in the housing - my hand doesn't even fit down there. RE: How do I ... - SL8RZZX3 - 06-15-2011 Do you have the Ford Racing Hids? Or the Svt Hids? I know there shouldn't be a diiference, but they could have changed the bulb holder to accommodate the DRL function maybe? I know mine has a wire clip with a plastic bulb socket that are a huge pain to try and change RE: How do I ... - ZTWsquared - 06-16-2011 (06-15-2011, 09:52 PM)SL8RZZX3 Wrote: Do you have the Ford Racing Hids? Or the Svt Hids? I know there shouldn't be a diiference, but they could have changed the bulb holder to accommodate the DRL function maybe? I know mine has a wire clip with a plastic bulb socket that are a huge pain to try and change Even worse - they are the Depo knock-offs ... any idea Gord where I could get me some of those wire clips RE: How do I ... - castone - 06-26-2011 Why not grab just some wire and wrap it around the clip to each screw, then use a small ratchet with and extension and a screw driver bit to tighten? |
