Transmission Woes - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Transmission Woes (/showthread.php?tid=2130) |
Transmission Woes - Jaigon - 01-10-2009 I got a check engine light after the transmission started acting up. 206,000 kms. I went to three places and they diagonosed it for free with the OBD reader. code was P0750 Tranmission Solenoid A... I hoping its just replacing the solenoid..Im going to take it to one of the shops monday to find out. Anyone else have this problem, and if so was the solution as easy as just replacing the solenoid? Thanks, 2002 Focus ZX5 Automatic 206,000Kms Transmission Woes - Jaigon - 01-10-2009 Jaigon,Jan 9 2009, 11:20 PM Wrote:I got a check engine light after the transmission started acting up. 206,000 kms. Transmission Woes - Jaigon - 01-10-2009 Jaigon,Jan 9 2009, 11:20 PM Wrote:I got a check engine light after the transmission started acting up. 206,000 kms. I guess no ones had this problem...I going to try to tackel this on my own...i found the part no Shift solenoid "A" (SSA) is part# XS4Z-7H148-AA ...I've been searching frantically on the other forums.. Transmission Woes - CanadaSVT - 01-11-2009 Stupid question but is this solenoid in or outside the trans? Transmission Woes - ZTWsquared - 01-11-2009 Jaigon,Jan 9 2009, 07:20 PM Wrote:I got a check engine light after the transmission started acting up. 206,000 kms. If I'm reading the DTCs correctly it isn't just the solenoid ... check out the differences between these four related DTCs. This is straight from my Ford DVD (for '07 mind you) ... PM me your email addy and I'll send you a PDF of the diagnostic tests for this DTC - it's a bit of an eye opener. P0750 -SSA Solenoid Circuit Failure Symptom: No reverse gear (short) or no 4th gear (open). MIL on. Description: SSA circuit failed to provide voltage drop across solenoid. Circuit open or shorted or PCM driver failure during on-board diagnostic. P0751 - SSA Functional Failure (Stuck Off) Symptom: Not all gears present, MIL on. Description: Mechanical or hydraulic failure of the shift solenoid. P0752 - SSA Functional Failure (Stuck On) Symptom: Not all gears present, MIL on. Description: Mechanical or hydraulic failure of the shift solenoid. P0753 - SSA Solenoid Circuit Failure Symptom: No reverse gear (short) or no 4th gear (open). MIL off. Description: SSA circuit failed to provide voltage drop across solenoid. Circuit open or shorted or PCM driver failure during on-board diagnostic. Transmission Woes - Spinal - 01-11-2009 my dad had the same problem on his fofo, it was just the solenoid that had to be replaced. i drove it while it was acting up and good lord when it shifted it felt like you revv'd up to 6k and dropped it in gear, that tranny must be pretty solid lol. Transmission Woes - Jaigon - 01-13-2009 UPDATE: So Saturday picked up the the solenoid "a" from the dealer and swapped it out . Problem is fixed. whew...when for a test drive and now is shifting properly to 4rth. So easy to do. The hardest thing was fighting with the last bolt from the pan...there are 20 and what do you know..the last one gave me a head ache. Transmission Woes - ZTWsquared - 01-13-2009 Jaigon,Jan 12 2009, 10:20 AM Wrote:UPDATE: Good job and congrats ... you should do up a how-to and post it. |
