Remote starter - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Marketplace (//www.focuscanada.net/forum/forumdisplay.php?fid=8) +--- Forum: Motormaniac (//www.focuscanada.net/forum/forumdisplay.php?fid=57) +--- Thread: Remote starter (/showthread.php?tid=22356) |
Remote starter - konafocuswrc - 10-15-2014 Warm up your car with a touch of button. No more shivering while your car warms up. Motormaniac can help you select to suit your needs. PM me for more detail. ![]() ![]() ![]() ![]() ![]() RE: Remote starter - hardk0re - 10-16-2014 Have you done any VW KESSY installs? RE: Remote starter - konafocuswrc - 10-16-2014 Done few, KESSY is no different than any Push To Start cars. Because being European cars, it still requires 1 key to be wrapped and hidden inside of car. Due to time consuming, installation labour won't be cheap. Most cars takes an hour and half to 2 hours to complete but this, I would say 4 hours+. RE: Remote starter - drunkinmonkey - 10-16-2014 I have a compustar auto start in my car already. is there anyway to just swap out the brain to make it an autostart and alarm? RE: Remote starter - konafocuswrc - 10-17-2014 Depends on which brain you have, it can be programmed to work as a factory alarm(no siren, no shock sensor). or swap out but again, depends on the brain. Wire harness may plug and play. Also door pins, hood pins and trunk pins required to be wired. RE: Remote starter - drunkinmonkey - 10-17-2014 not sure what brain is in the car, cause it already came installed all I know is the keyfob says 1WAMR-PRO RE: Remote starter - konafocuswrc - 10-17-2014 I am sure it is CM4200, which is only meant to use as a starter only. If it was FT-6200S, it can be programmed as a factory alarm. RE: Remote starter - hardk0re - 10-17-2014 let me see about getting a 3rd key programmed from VW as all things VW won't be cheap but I require 2 physical keys... RE: Remote starter - konafocuswrc - 11-23-2014 Bring your own remote starter and will install for you. Canadian tires have Prostart on sale. |
