Zx3 Cd Player In E150 Van...? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on I.C.E. (//www.focuscanada.net/forum/forumdisplay.php?fid=23) +--- Thread: Zx3 Cd Player In E150 Van...? (/showthread.php?tid=2524) |
Zx3 Cd Player In E150 Van...? - Chromey - 10-11-2008 Can i pull the Stock AM/FM unit outa my Work van And Put my CD player from my FOFO in... ANd Will it work? Zx3 Cd Player In E150 Van...? - NefCanuck - 10-11-2008 Depends I think on the MY of the Focus and the E150 (though from what little I know of the E150, that thing probably has a rather basic wiring harness on it, probably only has to drive two speakers fer instance :huh:) NefCanuck Zx3 Cd Player In E150 Van...? - habmann - 10-11-2008 I tried this with my E150 work truck when i used to have it and the wiring harness in the E150 was different than the plug in the back of fofo radio. I did have an idea to try and make a cheater harness that would plug into the E150 harness on one side and the fofo radio on the other. Never did get around to it tho Zx3 Cd Player In E150 Van...? - hardk0re - 10-11-2008 I fit the focus deck into a 98 windstar, worked fine, I just got one of those adapter harnesses for the windstar and soldered it right to the back of the deck to the pins. Worked fine. Zx3 Cd Player In E150 Van...? - Frost__2001 - 10-12-2008 I should mention depending on what Focus you own you might not be able to fit the radio into the Focus dash as the 00 - 04 is curved, and the raido will be more or less busting out at the seems. and the 2008+ radio is intergraded into the dash a la civic. Zx3 Cd Player In E150 Van...? - paolo - 12-13-2008 i successfully put both types of focus radios in an explorer sport and vice a versa.. fit was perfect, but wiring was just required to be changed. |
