In-dash Dvd Deck - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Classifieds (//www.focuscanada.net/forum/forumdisplay.php?fid=5) +--- Forum: Sell Items (//www.focuscanada.net/forum/forumdisplay.php?fid=26) +--- Thread: In-dash Dvd Deck (/showthread.php?tid=2579) |
In-dash Dvd Deck - konafocuswrc - 10-04-2008 ![]() I have power acoustik PTID-4006T, had this unit for 6 month i guess.. only used for 20 mins 5 days a week for 6 months.. not abused.. I can install this for you if you want to, at no charge, i will give you harness, mounting kit and antenna adaptor as well..($70 worth) I will let this go for $140.. ââ¬Â¢ Fully Motorized detachable 5 position drop screen with last angle memory ââ¬Â¢ Razor front panel with back-lit EL sheet for night viewing ââ¬Â¢ DVD, CD, MP-4, MP-3, CDR, CDRW Player NTSC/PAL compatible ââ¬Â¢ All functions are displayed on screen via OSD (sixteen languages) ââ¬Â¢ 30-second electronic anti-shock mechanism ââ¬Â¢ SD Card Slot for MP-3 Music or MP-4 Movies (memory not included) ââ¬Â¢ Accessory I-Pod Input Connection (Cable not Included) ââ¬Â¢ USB mini input for MP-3 Music or MP-4 Movies ââ¬Â¢ Antenna trigger wire ââ¬Â¢ Amplifier trigger wire ââ¬Â¢ Brake screen safety trigger ââ¬Â¢ Telephone Mute trigger wire for Blue Tooth adaptation ââ¬Â¢ AM/FM with 30 pre-sets (18/FM ââ¬â 12AM) ââ¬Â¢ 4-channel high power 50 x 4 channels (mosfet power) ââ¬Â¢ 1-Auxiliary Input for Back-up Camera ââ¬Â¢ 1-A/V in for secondary source input ââ¬Â¢ 1-RCA Output ââ¬Â¢ LO/DX and stereo mono selector switch ââ¬Â¢ Electronic (Bass, Treble, Volume, Balance, Fader) ââ¬Â¢ Pre-set EQ functions (Rock, Pop, Classic) ââ¬Â¢ Digital Clock ââ¬Â¢ DVD, PAL/NTSC selectable ââ¬Â¢ Panel brightness 300 NIT ââ¬Â¢ ISO/DIN Mount ââ¬Â¢ Full function remote control ââ¬Â¢ 4 screen modes ââ¬Â¢ Last position DVD memory In-dash Dvd Deck - Tiketz - 10-04-2008 Good deal and great seller In-dash Dvd Deck - j3rt - 10-04-2008 USB on the front or back? Is the bluetooth function included or is 'capable' with add-on parts/module? In-dash Dvd Deck - konafocuswrc - 10-04-2008 no bluetooth, Telephone Mute trigger wire for Blue Tooth adaptation is for when you add bluetooth unit, something like parrot or motorola car kit, then this wire will be wired too bluetooth car kit.. usb is on front but it neeeds mini adaptor..take a look at the pic closely, you will see what i mean.. In-dash Dvd Deck - Dimitri - 10-05-2008 What size is the screen? In-dash Dvd Deck - konafocuswrc - 10-05-2008 Dimitri,Oct 4 2008, 01:21 PM Wrote:What size is the screen? 3.5" In-dash Dvd Deck - konafocuswrc - 10-05-2008 another note, i m being honest with you guys.. i used switches in line on accessary wire to turn it on and off whenever i want instead of pres button and hold.. then today i tried regular way, without using switches, then this deck output wasn't working, then i had to press source button to get sounds back.. well this is the only thing i can found out..this could be way it is but there is nothing wrong with sound..and video.. In-dash Dvd Deck - konafocuswrc - 10-07-2008 $120, i will even put switches for you.. In-dash Dvd Deck - konafocuswrc - 10-09-2008 SOLD |
