6x8 Infiniti Speaker Help! - Printable Version
+--- Thread: 6x8 Infiniti Speaker Help! (/showthread.php?tid=5583)
6x8 Infiniti Speaker Help! - Alec Brandon - 05-28-2007
So I purchased a set of Infinit 6812CF speakers, pulled the car apart and was ready to install them.
The stock speakers wires go into a connector and plug/clip into the factory speakers.
I have cut of the connector, extended the wires (because they are too short) and added terminals to the end.
The problem is, the negative terminal on my new infiniti speaker is really small and the terminal won't clip on. Do I need a special type of connector???
Help, as I want to put my car back together.
6x8 Infiniti Speaker Help! - MAlby7 - 05-28-2007
Ya the terminals on the speakers are two different sizes. You need to use the two different size of female connectors.
6x8 Infiniti Speaker Help! - Mason - 05-28-2007
MAlby7,May 27 2007, 12:28 PM Wrote:Ya the terminals on the speakers are two different sizes.  You need to use the two different size of female connectors.
[right][snapback]239660[/snapback][/right]
U can just cut the connector off and use the wire direct to the speaker.
Or add 2 clips, up to you.
