Exhaust Help Needed! - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Exhaust Help Needed! (/showthread.php?tid=9500) |
Exhaust Help Needed! - CAMB - 05-31-2006 Hey there; I'm new to this forum, just installed a pacesetter shorty header and looking to install a MBRP system in my 2000 ZX3... Only thing is that I want a 2.5" systm which MBRP has only for the 2002- up SVT Focus..... Will this system fit on my 2000 ZX3? Thanks for the help!! Exhaust Help Needed! - Burnin21 - 05-31-2006 From what I know the SVT system will fit but it will stick out an additional few inches (it'll look funny). But someone correct me if i'm wrong. Not to mention you really dont need the 2.5" exhaust, for normal bolt on's 2.25" should be just fine. Thats what i'm running on my car and it sounds awsome, and the performance is great. I couldn't be happier. Exhaust Help Needed! - hardk0re - 05-31-2006 If your still running a stock catalytic you will want to replace that before the exhaust. A high flow exhaust and header and a stock cat is not efficient. Exhaust Help Needed! - CAMB - 05-31-2006 What I'm going to do is actually rip th cat right out, and just get a shop to fabricate a straight pipe down to the flex and then connect it to the 2.5" exhaust, my reasoning for the 2.5" exhaust is that I eventually want to do a FI setup (probably turbo charging it) and I have heard that with FI you want to run a 2.5" or even 3" exhaust.... Exhaust Help Needed! - CAMB - 05-31-2006 What I'm going to do is actually rip th cat right out, and just get a shop to fabricate a straight pipe down to the flex and then connect it to the 2.5" exhaust, my reasoning for the 2.5" exhaust is that I eventually want to do a FI setup (probably turbo charging it) and I have heard that with FI you want to run a 2.5" or even 3" exhaust.... is that correct? Thankfully I live in Redneck Alberta where we don't test for emmisons.... Go Oilers!!!! Exhaust Help Needed! - scoobasteve - 05-31-2006 apparently the flange is slightly different too. |
