Threads: 190
I think so, anyways.
1-2 shift is good and crisp.
2-3 seems ok also
3-4 it depends on what I'm doing. On normal roads, it sometimes shudders when it shifts. If I'm on the highway and I boot it a bit to pass someone, it seems like it disengages the gear, revs, and eventually hits the next gear.
I'm a bit overdue on a fluid change (checked the fluid yesterday, and its a bit off color and feels slightly gritty [never came across THAT before], but no noticeable burning smell, and not sure if the last time I had it changed that they replaced the filter). Think a clogged/dirty filter could be causing the problem?
I'm thinking of doing a fluid/filter change myself to see if that clears things up.
Yes, a swap would be nice, and I'm not in the market to get rid of my car and buy a new one with a 5 speed. But if you know of anyone who CAN do this sort of thing PROPERLY I'd really consider it because thats what I originally wanted but couldn't wait for one to show up at the stealership when I got this one.
Barring that:
If a fluid/filter change doesn't fix things and a swap is out of the question I want to rebuild it sooner than later -- any recommendations for a GOOD shop? I'm afraid of taking my car to anyone in the yellow pages because I'm very leary of going to a mechanic I don't know (read above on last fluid change).
Team PITA
Threads: 313
21
05-22-2009, 12:09 AM
(This post was last modified: 05-22-2009, 12:09 AM by ZTWsquared.)
torradan,May 21 2009, 08:35 AM Wrote:I think so, anyways.
2-3 seems ok also
3-4 it depends on what I'm doing.ÃÂ On normal roads, it sometimes shudders when it shifts.ÃÂ If I'm on the highway and I boot it a bit to pass someone, it seems like it disengages the gear, revs, and eventually hits the next gear.
I'm a bit overdue on a fluid change (checked the fluid yesterday, and its a bit off color and feels slightly gritty [never came across THAT before], but no noticeable burning smell, and not sure if the last time I had it changed that they replaced the filter).ÃÂ Think a clogged/dirty filter could be causing the problem?
Yes, a swap would be nice, and I'm not in the market to get rid of my car and buy a new one with a 5 speed.ÃÂ But if you know of anyone who CAN do this sort of thing PROPERLY I'd really consider it because thats what I originally wanted but couldn't wait for one to show up at the stealership when I got this one.
Barring that:
If a fluid/filter change doesn't fix things and a swap is out of the question I want to rebuild it sooner than later -- any recommendations for a GOOD shop?ÃÂ I'm afraid of taking my car to anyone in the yellow pages because I'm very leary of going to a mechanic I don't know (read above on last fluid change).
[right][snapback]287678[/snapback][/right]
I'm no expert ... but what you describe also sounds like the torque converter locking and unlocking (and more specifically locking/unlocking improperly) ... how many klicks do you have ... or is your car still in miles?
Threads: 291
4
omg u r having same problem as mine..
i have problem with reverse, it takes time..so ppl think i m driving manual..
next month, going to do tranny filter, fluid change..
Threads: 190
05-22-2009, 12:20 AM
(This post was last modified: 05-22-2009, 12:30 AM by torradan.)
Still in miles.. its at close to 54k miles now, so ~87k km.
Maybe I'll have to throw a Torque Converter into the mix if/when pulling the tranny out happens if that is indeed the problem. Budget is sort of tight, so trying to keep it as cheap as possible.
edit:
Just thinking.. torque converter acting wonky = possible lack of fluid going through it = clogged/filthy filter?
Team PITA
Threads: 291
4
mine 85k miles..
i found out that trans filter and fluid has to be changed every 30000 miles..
i've never done that before, so i will try filter and fluid first..as my budget is also tight..
if this is not doing anything, gotta ddo manual swap or call lentech..
Threads: 235
3
I heard some ppl having problems with the Silinoids.
I haven't yet but Spinal has before on his dad's Focus.... I think???
Threads: 117
my focus also just started to grind hard going into 3rd every other gear is good. i have no idea what could be the problem.
any one help my car i 5spt and has 195k
2002 red SVT sport'in European Appearance package rims, AEM cai, #4111 of 4788, ranger 12v plug cover, 4500k HID HI/LO, eibach springs, H&R 15mm wheel spacers. sold
2000 yellow zx3 sold
1994 mazda mx3 sold
1992 ford festiva (RIP)
Threads: 383
Jmountney1,May 21 2009, 03:21 PM Wrote:my focus also just started to grind hard going into 3rd every other gear is good. i have no idea what could be the problem.
[right][snapback]287732[/snapback][/right]
Same here especially when under load I had to granny shift it at the track way to many times. Just woundn't bang in.
DruZX3 You Tube Page
My Rides on Car Domain
