Suspension Question
I changed my Springs again... Issue Is, My front left strut Wont tighten, The Main Bolt just spins with the Shaft.
Is this a broken mount.?
(06-06-2010, 11:16 PM)Chromey Wrote: I changed my Springs again... Issue Is, My front left strut Wont tighten, The Main Bolt just spins with the Shaft.
You can stop the shaft from turning by putting the appropriate screwdriver or bit right into the top of the shaft - you can then use an open wrench to tighten the nut.
The shaft spinning is fairly normal - it's no indication of anything broken.
might be what i forgot to do this time... LOL Ill check.
This is my 4th set of springs... I hate spring sag.
you will need to use allen key to stop shaft from spinning..
do not use hex, it will damage and you will end up using vice grip..
(06-09-2010, 02:58 AM)konafocuswrc Wrote: you will need to use allen key to stop shaft from spinning..
Exactly What I forgot to do... All fixed now.
  Front Suspension Question muttsnutts 19 7,456 09-09-2012, 11:03 AM
Last Post: muttsnutts
  Suspension question. Focus man. Focus. 13 5,217 05-13-2011, 09:03 AM
Last Post: GFXjamie
  suspension question blue_light 6 4,115 02-12-2011, 10:44 AM
Last Post: ZTWsquared
  Svt Suspension Question......help imncrxtc 29 11,282 12-08-2009, 08:25 AM
Last Post: NikiterZTS
  Aftermarket Suspension/brakes/ Endlink Question. darkpuppet 4 2,362 01-22-2005, 12:45 AM
Last Post: darkpuppet
