How-to: All How-to Documents In Pdf
See the attached files below.. A huge thanks for Focus man, Focus for posting them!
(updated for new content)
All How-to's transfered from the old Downloadable file.
Performance Related Mod's
.pdf   Accel Coil Pack Upgrade - SPI.pdf (Size: 44.84 KB / Downloads: 34)
.pdf   AEM Cam Gears.pdf (Size: 334.09 KB / Downloads: 13)
.pdf   AEM Short Ram Intake.pdf (Size: 282.49 KB / Downloads: 12)
.pdf   AEM SVT CAI.pdf (Size: 314.93 KB / Downloads: 7)
.pdf   AEM Zetec CAI.pdf (Size: 329.08 KB / Downloads: 13)
.pdf   Aftermarket Cat-back Exhaust.pdf (Size: 57.54 KB / Downloads: 18)
.pdf   Aftermarket chip install.pdf (Size: 444.53 KB / Downloads: 7)
.pdf   Aftermarket Plug Wires.pdf (Size: 51.38 KB / Downloads: 10)
.pdf   Airbox Resonator Removal.pdf (Size: 138.61 KB / Downloads: 16)
.pdf   B+M STS.pdf (Size: 155.33 KB / Downloads: 2)
.pdf   Camshaft Installation.pdf (Size: 173.06 KB / Downloads: 6)
.pdf   Custom-fab heat Shield Plans.pdf (Size: 237.03 KB / Downloads: 8)
.pdf   FC 65mm TB.pdf (Size: 315.04 KB / Downloads: 3)
.pdf   FocusSport Driver\'s side Engine Mount.pdf (Size: 44.35 KB / Downloads: 8)
.pdf   FocusSport UDP - Zetec.pdf (Size: 288.76 KB / Downloads: 11)
.pdf   Iceman Clone.pdf (Size: 123.84 KB / Downloads: 10)
.pdf   Iceman Intake.pdf (Size: 279.89 KB / Downloads: 6)
.pdf   Improving Chassis Ground.pdf (Size: 50.24 KB / Downloads: 7)
.pdf   JBA Shorty Header.pdf (Size: 367.34 KB / Downloads: 9)
.pdf   K+N Drop-in Filter.pdf (Size: 137.83 KB / Downloads: 6)
.pdf   MAC Shorty Intake.pdf (Size: 322.27 KB / Downloads: 5)
.pdf   Porting Zetec TB.pdf (Size: 45.92 KB / Downloads: 6)
.pdf   Screamin Demon Coil and Wires.pdf (Size: 282.68 KB / Downloads: 6)
.pdf   SPI Shorty Header.pdf (Size: 427.99 KB / Downloads: 6)
.pdf   SPI TB Swap with Mustang TB.pdf (Size: 72.27 KB / Downloads: 4)
.pdf   SVT Snorkel.pdf (Size: 47.56 KB / Downloads: 7)
.pdf   SVT TC Kill Switch.pdf (Size: 793.32 KB / Downloads: 8)
.pdf   UDP Iinstall - ZETEC.pdf (Size: 78.93 KB / Downloads: 10)
.pdf   VF Engineering Rear Engine Mount.pdf (Size: 1.21 MB / Downloads: 8)
.pdf   Volant and SVT Snorkel.pdf (Size: 334.17 KB / Downloads: 7)
Brakes - Suspension - Tires.
.pdf   Brake System Bleeding.pdf (Size: 147.37 KB / Downloads: 10)
.pdf   Changing Brake Calipers.pdf (Size: 237.2 KB / Downloads: 11)
.pdf   Changing Brake Disc (Rotors).pdf (Size: 305.73 KB / Downloads: 11)
.pdf   Changing Brake Shoes.pdf (Size: 626.55 KB / Downloads: 11)
.pdf   Changing Rear Brake Pads.pdf (Size: 148.88 KB / Downloads: 9)
.pdf   Front Wheel Stud Replacement.pdf (Size: 44.41 KB / Downloads: 14)
.pdf   Inner Tie Rod Replacement.pdf (Size: 44.9 KB / Downloads: 10)
.pdf   Lowering Springs Install.pdf (Size: 49.38 KB / Downloads: 14)
.pdf   LPE Rear Shock Mount Shims Install.pdf (Size: 514.93 KB / Downloads: 3)
.pdf   Progressive Rear Anti-Sway Bar Install.pdf (Size: 264.09 KB / Downloads: 7)
.pdf   Rear Brake Squeal Fix.pdf (Size: 115.55 KB / Downloads: 9)
.pdf   Rear Camber Bolts Install.pdf (Size: 275.77 KB / Downloads: 7)
.pdf   Removing Rear Brake Drum.pdf (Size: 220.45 KB / Downloads: 15)
.pdf   Replacing Front Control Arm.pdf (Size: 47.72 KB / Downloads: 9)
.pdf   Replacing Shocks and Struts.pdf (Size: 456.2 KB / Downloads: 12)
.pdf   Sway Bar End Link Replacement.pdf (Size: 274.91 KB / Downloads: 11)
.pdf   Upper Strut Bar Install.pdf (Size: 144.54 KB / Downloads: 8)
Exterior Mods.
.pdf   Aftermarket Hood Install.pdf (Size: 55.98 KB / Downloads: 6)
.pdf   Antenna Base Removal.pdf (Size: 202.53 KB / Downloads: 9)
.pdf   Billet Fuel Door Install.pdf (Size: 210.68 KB / Downloads: 14)
.pdf   Body Kit Installation.pdf (Size: 64.18 KB / Downloads: 11)
.pdf   Clear Corners Install.pdf (Size: 213.72 KB / Downloads: 9)
.pdf   Debadging Your Focus.pdf (Size: 259.41 KB / Downloads: 12)
.pdf   DIY SVT-style Headlights.pdf (Size: 49.01 KB / Downloads: 25)
.pdf   DRL Fog Light Mod.pdf (Size: 441.23 KB / Downloads: 42)
.pdf   Engine Bay Painting How-to.pdf (Size: 862.41 KB / Downloads: 10)
.pdf   Euro Grille Upper Light Mod.pdf (Size: 262.13 KB / Downloads: 5)
.pdf   Euro Mirror Install.pdf (Size: 760.96 KB / Downloads: 10)
.pdf   Euro Tail Lights Mod.pdf (Size: 172.16 KB / Downloads: 14)
.pdf   Front Bumper Cover Removal.pdf (Size: 300.52 KB / Downloads: 7)
.pdf   Halo wiring diagram.pdf (Size: 256.37 KB / Downloads: 16)
.pdf   Independent Fog Lights Mod.pdf (Size: 202.15 KB / Downloads: 16)
.pdf   Make Your Own Shorty Antenna.pdf (Size: 297.65 KB / Downloads: 15)
.pdf   Minor Paint Touchups.pdf (Size: 147.37 KB / Downloads: 6)
.pdf   OFOC DRL Fog light mod.pdf (Size: 227.42 KB / Downloads: 20)
.pdf   Painting Exterior Body Trim.pdf (Size: 150.43 KB / Downloads: 8)
.pdf   Rear Bumper Cover Removal.pdf (Size: 256.55 KB / Downloads: 7)
.pdf   Rear Drums Painting.pdf (Size: 217.48 KB / Downloads: 7)
.pdf   Rear Lift Gate Handle Swap.pdf (Size: 147.49 KB / Downloads: 11)
.pdf   Re-sealing and Waterproofing Tail Lights.pdf (Size: 245.2 KB / Downloads: 6)
.pdf   Side Mirror Painting.pdf (Size: 52.58 KB / Downloads: 11)
.pdf   ST170 Headlights Install.pdf (Size: 285.56 KB / Downloads: 9)
.pdf   Upper Grille Lights Delete.pdf (Size: 299.76 KB / Downloads: 9)
.pdf   Valve Cover Painting How-to.pdf (Size: 1.85 MB / Downloads: 3)
.pdf   Zetec Spark Plug Wire Cover Install.pdf (Size: 40.8 KB / Downloads: 4)
General Service and Maintenance.
.pdf   Battery Charging.pdf (Size: 161.9 KB / Downloads: 3)
.pdf   Brake System.pdf (Size: 145.53 KB / Downloads: 6)
.pdf   Cabin Air Filter Install.pdf (Size: 131.46 KB / Downloads: 29)
.pdf   Changing Your Factory Air Filter.pdf (Size: 45.46 KB / Downloads: 17)
.pdf   Changing Your Oil.pdf (Size: 44.57 KB / Downloads: 12)
.pdf   Checking Engine Oil Level.pdf (Size: 240.9 KB / Downloads: 6)
.pdf   Cooling System Flush Drain and Bleed.pdf (Size: 146.52 KB / Downloads: 8)
.pdf   Fender Bulb Replacement How-to.pdf (Size: 232.75 KB / Downloads: 4)
.pdf   Fuel System Description.pdf (Size: 210.27 KB / Downloads: 5)
.pdf   Gasoline Terminology Explained.pdf (Size: 111.22 KB / Downloads: 10)
.pdf   General Focus FAQs.pdf (Size: 147.83 KB / Downloads: 25)
.pdf   Jacking Points.pdf (Size: 218.6 KB / Downloads: 21)
.pdf   Lifting and Hoisting Points.pdf (Size: 199.31 KB / Downloads: 12)
.pdf   Replacing Front Grille Turn Signal Bulb How-to.pdf (Size: 210.95 KB / Downloads: 5)
.pdf   Replacing Rear Bulbs - ZX3 and 5.pdf (Size: 192.53 KB / Downloads: 10)
.pdf   Tire Jack Re-stowage Guide.pdf (Size: 179.75 KB / Downloads: 10)
.pdf   VIN Decoder Guide.pdf (Size: 98.83 KB / Downloads: 23)
.pdf   Wheel Removal and Install.pdf (Size: 144.52 KB / Downloads: 7)
Interior Mods.
.pdf   Aftermarket E-Brake Handle Install.pdf (Size: 129.84 KB / Downloads: 10)
.pdf   Aftermarket HVAC Knob Install.pdf (Size: 102.37 KB / Downloads: 5)
.pdf   Aftermarket Pedal Install.pdf (Size: 1.01 MB / Downloads: 4)
.pdf   A-Pillar Gauge Pod Install.pdf (Size: 111.87 KB / Downloads: 7)
.pdf   Audio Amp Install.pdf (Size: 192.28 KB / Downloads: 9)
.pdf   Billet Aluminum Pedal Cover Install.pdf (Size: 118.14 KB / Downloads: 2)
.pdf   Colour-modding Stock Instrument Faces.pdf (Size: 124.91 KB / Downloads: 9)
.pdf   Complete Dash Colour How-to.pdf (Size: 932.07 KB / Downloads: 13)
.pdf   Contour Zetec Valve Cover Painting.pdf (Size: 993.07 KB / Downloads: 6)
.pdf   Door Panel Inset How-to.pdf (Size: 335.9 KB / Downloads: 7)
.pdf   Door Sill Install.pdf (Size: 150.64 KB / Downloads: 6)
.pdf   Ford Racing Oil Pressure Gauge Install.pdf (Size: 210.85 KB / Downloads: 8)
.pdf   Front Door Interior Panel Removal.pdf (Size: 279.58 KB / Downloads: 9)
.pdf   Gauge Face Install.pdf (Size: 86.04 KB / Downloads: 5)
.pdf   Gear Shift Console Surround Install.pdf (Size: 134.19 KB / Downloads: 8)
.pdf   Glove Box Removal How-to.pdf (Size: 39.81 KB / Downloads: 10)
.pdf   IndiGLO Odometer Hack.pdf (Size: 314.66 KB / Downloads: 10)
.pdf   Interior Paint Preparations.pdf (Size: 189.16 KB / Downloads: 8)
.pdf   LED Vent Illumination How-to.pdf (Size: 490.28 KB / Downloads: 12)
.pdf   Make Your Own Blaupunkt MP3 Harness.pdf (Size: 156.57 KB / Downloads: 8)
.pdf   Making a Fiberglass Gauge Pod.pdf (Size: 202.2 KB / Downloads: 7)
.pdf   Making a Speaker Enclosure.pdf (Size: 520.07 KB / Downloads: 4)
.pdf   Manual Window Crank Removal.pdf (Size: 54.17 KB / Downloads: 7)
.pdf   Mudflaps Install.pdf (Size: 1.55 MB / Downloads: 5)
.pdf   Painting Interior Trim How-to.pdf (Size: 232.62 KB / Downloads: 7)
.pdf   Radar Detector Install.pdf (Size: 153.17 KB / Downloads: 6)
.pdf   Rear Quarter Trim Removal.pdf (Size: 166.39 KB / Downloads: 6)
.pdf   Rear Seat Cargo Mode How-to.pdf (Size: 178.3 KB / Downloads: 9)
.pdf   Shifter Boot Install.pdf (Size: 104.38 KB / Downloads: 7)
.pdf   Stereo Bezel Removal.pdf (Size: 1,004.1 KB / Downloads: 10)
.pdf   Stock Stereo Removal.pdf (Size: 204.94 KB / Downloads: 19)
Misc Asthetic Mods
.pdf   Automatic Door-locking Disable How-to.pdf (Size: 170.86 KB / Downloads: 21)
.pdf   Calibrating Extra Keys How-to.pdf (Size: 303.52 KB / Downloads: 25)
.pdf   Electronic Test Mode How-to.pdf (Size: 168.54 KB / Downloads: 14)
.pdf   Gauge Cluster Removal How-to.pdf (Size: 243.88 KB / Downloads: 6)
.pdf   Gauge Needle Calibration How-to.pdf (Size: 187.43 KB / Downloads: 10)
.pdf   Intermittent Wiper Mod How-to.pdf (Size: 175.1 KB / Downloads: 15)
.pdf   Keyless Entry Single Button-press Mod How-to.pdf (Size: 169.32 KB / Downloads: 11)
.pdf   Programming New Keyless Remotes How-to.pdf (Size: 41.6 KB / Downloads: 11)
.pdf   Seatbelt Reminder Activate or Deactivate Mod.pdf (Size: 169.71 KB / Downloads: 7)
.pdf   Stock Alarm Adjustment How-to.pdf (Size: 172.87 KB / Downloads: 12)
Misc Mechanical Mods - Articles
.pdf   Accelerator Cable Removal.pdf (Size: 260.32 KB / Downloads: 6)
.pdf   Accessory Drive Belt Replacement.pdf (Size: 441.23 KB / Downloads: 4)
.pdf   Adjusting MTX-75 Shift Cables.pdf (Size: 145.45 KB / Downloads: 10)
.pdf   Checking for Vacuum Leaks.pdf (Size: 145.68 KB / Downloads: 11)
.pdf   DPFE Service and Repair.pdf (Size: 210.13 KB / Downloads: 12)
.pdf   Finding your PCM Code.pdf (Size: 285.75 KB / Downloads: 9)
.pdf   Installing Amsoil Dual-remote Oil Filter.pdf (Size: 1.23 MB / Downloads: 6)
.pdf   Remove and Install Zetec Windage Tray and Oil Pickup.pdf (Size: 147.99 KB / Downloads: 4)
.pdf   Remove and or Replace Fuel Rail and Injectors.pdf (Size: 534.07 KB / Downloads: 7)
.pdf   Remove and Replace Zetec Alternator.pdf (Size: 420.18 KB / Downloads: 8)
.pdf   Remove and Replace Zetec Oil Pan.pdf (Size: 146.37 KB / Downloads: 4)
.pdf   Remove Intake Manifold and or Replace IAC Valve.pdf (Size: 579.17 KB / Downloads: 7)
.pdf   Remove Zetec Engine.pdf (Size: 165.89 KB / Downloads: 13)
.pdf   Removing and or Installing the ATX Trans.pdf (Size: 154.61 KB / Downloads: 2)
.pdf   Replacing the Thermostat and or Housing.pdf (Size: 137.29 KB / Downloads: 6)
.pdf   Starter Motor Remove and Replace.pdf (Size: 570.01 KB / Downloads: 7)
.pdf   Testing the Thermostat.pdf (Size: 144.39 KB / Downloads: 5)
And that is the lot of them. All that were in the original ZIP File anyhow. Enjoy and happy modding. Tongue
This needs to be a sticky.
DruZX3 You Tube Page
My Rides on Car Domain
It better be after all the work I put into it yesterday. The wife was pissed that I spent the whole night uploading to FC.net
see.. I give us the ability to attach stuff now -- who's your favourite admin? Tongue
thanks man.. really appreciate your efforts in uploading all that stuff!
<edit> -- I went and deleted the posts prior to focus man's... so apologies if any of ya's got stuck in the middle -- just wanted the how-to's at the top! </edit>
(06-03-2010, 11:39 AM)Focus man. Focus. Wrote: Misc Asthetic Mods
The specified attachment does not exist.
Oh no.... Not again.
(07-21-2016, 12:04 AM)Focus man. Focus. Wrote: Oh no....  Not again.
Yep, I get the same message "The specified attachment does not exist."  on every one of the links I tried. Tried sending a messaage, message returned. So posting here.
