Wire Color Codes
hey if anyone can help I need to know which wire is the sensor signal and which is the 12volt. I am talking about the wires between the Second o2 sensor and its wiring harnesss..I have:
1 black
1 grey
2 white
which is which, a 12volt, a sensor signal and 2 grounds
OFFICAL FC BABYSITTER
there should only be one ground. the other is the heating wiring, cause if you have a 4 wire o2 sensor, one wire is the sensor, one ground, one 12v and one heating wire.
jarrod are you hooking up an air/fuel gauge, cause if you are then you should use the sensor before the cat(if you have one) or your not going to get a reading from the gauge.
'03 Focus SVT
I was just gonna say, I didnt see the 2nd O2 refrence. Def go with the first one!
Hey just wondering Im hooking mine up too, but on the SVT isn't one of the wires in the mass air connected to that? i cold be totally wrong and havent tried to hook it up yet, i was waiting for the pod to come back from paint but since the topic started?
David
[Image: sigfocuscanada.jpg]
nah its for an 02 cheater..
