05-10-2013, 11:16 AM
Duratec 2.0L/2.3L Crane Stage 2 Camshafts MANUAL TRANSMISSION ONLY!!!!!!! Too rough for Auto.
PERFORMANCE STREET /OPEN TRACK / DRAG RACE USE: 1500-7000RPM
Fair Idle, good low to mid range and strong top end power. Largest grind for automatic trans. For max HP use low restriction air intake, 1.75" header and 2.5" exhaust. Valve Springs and Retainers Required. Use 9.5-11.5:1 compression ratio. ECU Re-Flash Strongly Recommended.
Basic Operating RPM Range 1,500-6,500
Duration @ 050 inch Lift 226 int./216 exh.
Advertised Duration 248 int./238 exh.
Valve Lift with Factory Rocker Arm Ratio 0.410 int./0.385 exh.
Lobe Separation (degrees) 110
Intake Valve Lash 0.008 in.
Exhaust Valve Lash 0.010 in.
Grind Number F-226/410-2SR-10
________________________________________________________
When I had these in the car it pulled hard and was very fun to drive. It gave the car an exhaust note that is sooo sexy lol
Easy to install with timing tools and if kept @ factory REDLINE you may not need Valvesprings and Retainers.
Asking $200 Cash. Local GTA pick up/meet up
