Threads: 116
0
03-27-2007, 02:43 AM
(This post was last modified: 03-30-2007, 04:41 AM by zx5power.)
Well its been 3 days trying and still nothing , I can only get the red light on my amp and not green the power and ground is definatley good (checkedmulti) the remote and LOC wires are hooked up according to what you guys listed and nothing .
I have the remote wire to a Yellow / Green
Left Rear - white purple + and gray/white -
Right Rear - White + and gray -
and nothing , come on guys is the 2006 stereo different ? I have the single cd mp3 ... Need help
Ford Focus SES ZX5
TEAM DURATEC # 99
Threads: 163
0
Are you sure that is the right remote wire? i think that would be the only one i would question at this time. Is the AMP good? was it used or brand new?
--Henry Ford
00 Focus ZX3 Silver- Sold
01 Focus ZX3 Green- Sold
01 Focus ZTS Red- Sold
03 Focus ZTW Green Sold
04 Escape LTD Silver- Sold
05 Freestyle LTD Black-Sold
02 Honda CRV EX-L-Sold
11 VW Jetta TDI 6spd Mine
Threads: 98
3
Threads: 54
Ya definately check the remote turn-on wire.
Also what does the red light mean? Does the manual for the amp give you any indication of what it means? Sometimes they'll blink in different patterns and such for different problems.
Current
09 F150 SCREW 4X4 XTR
Former
Show
Go
Threads: 116
0
good amp I tested it and it works , its gotta either be the Loc installed to the wrong wires , loc not working , or bad rca cables
Ford Focus SES ZX5
TEAM DURATEC # 99
Threads: 116
0
Red if its not good and green when it is pretty much lol
Ford Focus SES ZX5
TEAM DURATEC # 99
Threads: 116
0
ok well I put a jumper from remote to the 12v power and it stil lwont work so its gotta either be a mix up with wiring or something
Ford Focus SES ZX5
TEAM DURATEC # 99
Threads: 38
0
Sounds internal or, how is the amp getting the audio signal, if you are usings rca's check the input voltage. If not using RCA's and the factory line level outputs there could be a wiring issue, let me know.
David
Threads: 116
0
Theres rca for the audio signal to the amp but its wired to my stock deck with a loc . The volts at the power is fine is there a way to check with the multimeter if the rca is putting audio to the amplifier.
Ford Focus SES ZX5
TEAM DURATEC # 99
Threads: 98
0
zx5power,Mar 26 2007, 05:47 PM Wrote:Theres rca for the audio signal to the amp but its wired to my stock deck with a loc . The volts at the power is fine is there a way to check with the multimeter if the rca is putting audio to the amplifier.
[right][snapback]232059[/snapback][/right]
What kinda deck you have.
Does it have Pre-outs.
It sounds like the amp is staying in protect mode. Could even be the connection in your sub box. If your shorting out in there it would cause it.
Check your Actual sub wires
2000 ZX3
Threads: 116
0
Its the stock deck im trying to run a Line out convertor for rcs jacks , the subs are fine we tried them in a buddies car not long ago.
Ford Focus SES ZX5
TEAM DURATEC # 99
Threads: 38
0
you have to start eliminating things. If you disconnect everything from the amp except power, does it power up fine. If so you something outside the amp may be a problem
If it does power up fine add the speaker box. No input. This is a way to check the box
Now if that is ok add the input signal, if it then goes down, there is an issue with the input if not, reply and we try some other things
David
Threads: 116
0
03-28-2007, 09:03 AM
(This post was last modified: 03-28-2007, 09:14 AM by zx5power.)
seems like an issue with positive , remote and ground but I checkw ith multi and im getting 12.09 volts at positive and 12.09 volts from remote when I turn the key so I dont understand it and I check the multimeter with the ground so it must be good .
I hooked the amp up i nthe house to a old deck and a power box before putting it i nthe car and it worked so ...
maybe theres something with postive and remote im not sure
got the power hooked direct to battery with a fuse which is sending power ..
Got the ground bolted under the seatbelt anchor
Got the remote tapped into the Yellow/green ignition wire for the stereo
Ford Focus SES ZX5
TEAM DURATEC # 99
Threads: 116
0
Ford Focus SES ZX5
TEAM DURATEC # 99
Threads: 54
03-28-2007, 11:24 AM
(This post was last modified: 03-28-2007, 11:25 AM by habmann.)
Whats the impedance of your subs? And what configuration do you have them wired? If you've got less than 4ohms that might be whats causing your problem not to mention a 4 x 100W amp seems a lil undersized to power 2 subs.
Generally you can use a 2 channel amp bridged to run 2 subs but i've never heard of a 4 channel amp being used. There might be a reason to that and that might be whats causing your problem.
Current
Former
Show
Go
Threads: 116
0
without the subs even connected it wont turn green
Ford Focus SES ZX5
TEAM DURATEC # 99
Threads: 116
0
Well yesterday when I started the car I heard the amp turn on so I went to the trunk like a child in a candy store but the rca were unhooked once I plugged them in bam back to red so its got to be the line out convertor hooked up wrong
Ford Focus SES ZX5
TEAM DURATEC # 99
Threads: 54
zx5power,Mar 29 2007, 07:04 AM Wrote:Well yesterday when I started the car I heard the amp turn on so I went to the trunk like a child in a candy store but the rca were unhooked once I plugged them in bam back to red so its got to be the line out convertor hooked up wrong
[right][snapback]232377[/snapback][/right]
Ya no doubt it's the RCA's or the LOC if having them unplugged fixed the problem.
Current
Former
Show
Go
Threads: 116
0
I must have the wrong wires or the loc is no good ,
Ford Focus SES ZX5
TEAM DURATEC # 99
Threads: 116
0
ill take a picture later of the loc and the wire to wire colour maybe someone can figure out what im doing wrong
Ford Focus SES ZX5
TEAM DURATEC # 99
