Threads: 3
0
My 01 wagon started to hesitate today while i was driving with 2nd-4th gear about 1500-3000 rpm at constant speed. the idle is fine. while car in neutral, it seems to be fine when i kept the rpm at 1500-2500.
I had the the fuel pump/ fuel filter replaced about 2 years ago and fuel filter 1 year ago. i also check that harness which seems to be OK.
thanks.
any suggestion?
Threads: 411
pretty sure that fuel filter should be replaced at least once a year. I'd check that out 1st since its a 20 min job and you can pick up the part at most CT's.
Threads: 215
0
Flofocus,Aug 1 2006, 10:00 AM Wrote:pretty sure that fuel filter should be replaced at least once a year. I'd check that out 1st since its a 20 min job and you can pick up the part at most CT's.
[right][snapback]200168[/snapback][/right]
i believe the fuel filter is recomended every 20k. ive been doing mine every 15k.
'05 Grand Cherokee LTD Hemi
Threads: 215
0
Flofocus,Aug 1 2006, 11:20 AM Wrote:ZX5focused,Aug 1 2006, 10:15 AM Wrote:Flofocus,Aug 1 2006, 10:00 AM Wrote:pretty sure that fuel filter should be replaced at least once a year.ÃÂ I'd check that out 1st since its a 20 min job and you can pick up the part at most CT's.
[right][snapback]200172[/snapback][/right]
:o I thought I read in the service manual every 100K?
I am probably wrong though...
[right][snapback]200196[/snapback][/right]
i was having the same problem i talked to one of the techs at the dealer, he siad to check my maf wires, then check the fuel filter. i beleive its included in the recomended 20k service from ford.
Threads: 833
hmm I am having the same problems as I noticed recently... thought it was the feul pump...
Threads: 1
0
check fuel pump... don't go through the same misery as me!
2002 Ford Focus SVT CD Silver: Diablosport Predator performance tune, FC ORP plus Borla cat-back, FocusSport plug wires, FocusSport underdrive pulley kit, VF Engineering rear motor mount, K&N drop-in, FC short shifter, KW V1 coilovers, 17" Rota SubZeros w/ Yoko ES100's, shorty antena, tint, colour-matched trim[COLOR=gray]
Threads: 3
0
Problem solved!
DPFE replaced
:lol:
