Exhaust system for 2007 ST
#21
those clamps are fine... when you aren't cranking them on with an air impact so tight they break LOL
Yeah, the clamps should of held up I guess, but the guy said the pipes were still moving when and tried to go tighter the clamps broke because the stainless is fairly hard steel!
They only charged me 1.50$ for each clamp they used of theirs! 115$ total for installation including oil/filter change! Smile
2007 CD Silver ST  **** FOR SALE ****
2014 Performance Blue ST  **** SOLD ****
2016 Ford Edge Sport Shadow Black
yea, saddle clamps are crap... band clamps are the way to go... if we use saddle clamps at The Garage, we'll tack weld each seam to give it a little bit extra strength... and yea, probably shoulda got a resonator... easy to fix that though... measure the length of the straight piece after the two bolt flange and call up The Garage and we can ship you a resonator that you just cut into the straight part and clamp it down like your exhaust pipes
  Just Exhaust Or Full System Just4Derek 6 2,332 10-11-2006, 02:42 AM
Last Post: NikiterZTS
  Stock Exhaust System Size ThraxXx 25 7,749 01-18-2005, 07:01 AM
Last Post: ThraxXx
