Threads: 193
0
Well, I'm sure you might have been asked this before, but I'm wondering what brake kits you have available. Not nesacarily the big brake type, but just replacement in general...like flex lines, pads, rotors, and also calipers, rear drum-to-disc conversions, etc. Also, I am guessing that I'll need at least a 16" rim size minimum to fit anything bigger than stock right?
Any advice on the matter would be great...
Bleeding Ford Blue again...
Threads: 84
0
right now i'm currently sold out of my brake kits. the basic Focus brake kits i have consist of a pair of Brembo blank rotors, Hawk HPS pads and a 1L bottle of ATE Super Blue brake fluid(you should flush your fluid every 2years) for $280cnd plus tax and shipping. add in a set of SS brake lines for $150cnd.
i have this kit on more than a few cars out here and yet to have a single issue even on cars regularly Auto-X'ed
as for big brake kits.
i do not offer anything at this time, i can get the TCE kits which i believe are the best option out there for real "Big Brakes" but i make no money off these kits, i just bring them in as a favor to people. i'm trying to get my hands on a bat kit but bat doesn't want to give much in the way of a dealer discount... <_<
Threads: 193
0
Alright cool...do the blank rotors resist fade better than the stock ones? I'd like to have firmer brakes, and the stuff you put together sounds like it does...I'll give it some thought...thanks man.
Threads: 193
0
I follow...I just find that the front rotors (stockers) warp and/or fade quickly...as though they were meant for a lighter car or something. I don't drive my car abusively, I just want brakes that give me more brake fade resistance, and be able to shut the car down from highway speeds more often, rather than just slowing it down. I think you get what I mean...
Also, since I installed the suspension kit, if I use the breaks really hard, they lock easier now in the front...I'm wondering if this is because the car isn't transffering it weight over the front wheels as much, and the struts are pushing the tires harder into the road then the stockers did...
Either way, I like the sound of your kit, and would be interested in getting either it, or a used SVT brake system when/if you have them available...
Threads: 84
0
an SVT brake kit will cost a lot more than a basic brake upgrade.
as for your fade issues.... you would be surprized at what can cause the rotors to warp. you don't need to be hard on the brakes to warp the rotors although that does speed up the process! ;)
let me know when you were looking to do this, i need to place an order for pads soon anyways...
