Threads: 77
0
brucktown,Jul 8 2005, 02:34 PM Wrote:focuzedn2o,Jul 7 2005, 09:39 PM Wrote:wonuldn't it fawk ur drive axles? <_<
[right][snapback]120096[/snapback][/right]
hasn't done anything to mine, it is a very minor bend i am assuming, hardly noticable, like i said only under 5 km/h or between 110-120
[right][snapback]120320[/snapback][/right]
hmm for 200 bones I'd be very interested... have you tried to get them rebalanced? a static balancing might solve it??
***want to buy***
MBRP................ check
SCT Xcal2 ........ check
VF mounts
Adj. Dampers ... check
Meford's Mom.... sale pending
Threads: 64
0
check the true ness of the rims and a tire center - ther tell you right away if there bent
sounds like the same s**t i webt thru for 2 months
new rubbber?
my first problem was i had a bent belt in the tire
i had the same vibration with mine 110-125km
check your wheel bearing and tire pressure too(it runs higher 37-55) - but if you have new rubber on i say its your tires because i have bridgestone fusion zr1's and its the third set - now i can take it over 160 and absolute perfection
if the rims are good - bring them to the barrie bbq and il give you cash for them
pm me asap when you get results
