Source: Canadiandriver
May 10. 2007
Ottawa, Ontario - Transport Canada has issued its latest recalls, which may affect some Jaguar, Jeep and Dodge vehicles.
2007 Jaguar XKR
Vehicles affected: 27
On certain vehicles, the brake servo vacuum supply hose may be misrouted, which could cause the hose to be in close proximity to the EGR valve and attachments on the exhaust manifold. The hose may melt or could deteriorate over time, resulting in a leak and loss of brake assistance. Dealers will inspect the brake vacuum hose routing and adjust as necessary, and the hose will be replaced if there are signs of damage.
2007 Dodge Caliber
2007 Jeep Compass
2007 Jeep Patriot
Vehicles affected: 90
On certain vehicles, the length of the rear wheel hub mounting bolts may prevent proper actuation of the park brake. This could allow unintended movement of the vehicle under certain conditions. Dealers will replace the rear wheel hub mounting bolts and brake cable equalizer, and adjust the park brake system.
2007 Jeep Compass
2007 Jeep Patriot
Vehicles affected: 120
Certain vehicles fail to comply with CMVSS 108 - Lighting Systems & Retro-reflective Devices. The daytime running lamps were not properly configured during vehicle assembly and, as a result, may not be function. Dealers will inspect and, if required, update the configuration.
2007 Dodge Ram 2500
2007 Dodge Ram 3500
Vehicles affected: 1,200
Certain heavy-duty 2500/3500 chassis cab trucks fail to comply with CMVSS 108 - Lighting Systems & Retro-reflective Devices. The daytime running lamps were not properly configured during vehicle assembly and, as a result, may not be function. Dealers will inspect and, if required, update the configuration.
  Transport Canada issues latest recalls Frost__2001 1 2,251 09-29-2010, 01:52 PM
Last Post: reldridge
  Transport Canada announces latest recalls Frost__2001 1 2,413 08-19-2010, 02:34 PM
Last Post: Spinal
  Transport Canada issues latest recalls Frost__2001 2 2,482 07-17-2010, 12:02 AM
Last Post: NefCanuck
Information Transport Canada issues latest recalls Frost__2001 7 4,411 06-12-2010, 04:01 AM
Last Post: Mystake
  Transport Canada issues latest recalls Frost__2001 3 2,579 05-06-2010, 11:12 AM
Last Post: mo_focus
  Transport Canada Issues Latest Recalls Frost__2001 1 2,297 04-20-2010, 11:36 AM
  Transport Canada Issues Latest Recalls Frost__2001 7 3,838 03-31-2010, 01:37 AM
Last Post: Mystake
  Transport Canada Announces Latest Recalls Frost__2001 4 3,090 02-25-2010, 11:31 PM
Last Post: Scorcher000
  Transport Canada Issues Latest Recalls Frost__2001 0 1,917 02-10-2010, 10:22 PM
Last Post: Frost__2001
  Toyota Recalls 2.3 Million Cars In Canada And U.s. darkpuppet 15 7,576 02-03-2010, 02:53 AM
