Throttle Body Spacer
Is it worth it? Anybody done this mod yet?
focusonthis_88,Sep 3 2006, 11:15 AM Wrote:Is it worth it?  Anybody done this mod yet?
[right][snapback]205230[/snapback][/right]
Generally throttle body spacers on an injected engine are useless.
The purpose of spacers on a carbureted car serve to change the airflow and give more time for the fuel to mix with air more uniformly.
Since our engines inject the fuel into the intake runners directly before the head, you could add a 20" spacer and it would not change anything, except usually add turbulence to the airflow system, which makes it worse, not better.
Unless you're using the spacer as a port for nitrous (and to be honest, I haven't looked at a spray setup on our cars and don't know if that's where it's injected into the system (it is in a carbureted car)), I would say you're wasting money.
Everything I've ever read about this mod says that it's a HUGE waste of time and effort. if you're going to take the TB off, you may as well remove the intake manifold at the same time and PnP it.
  Throttle-body spacers rnzo86 4 2,889 12-23-2012, 12:15 AM
Last Post: ZTWsquared
  Throttle Body - Worth The Hasel? Alec Brandon 15 5,842 04-06-2007, 04:17 AM
Last Post: SmokeBCBuDZ
  Help: Throttle Body Question focus19 4 2,275 10-29-2006, 03:20 PM
Last Post: NikiterZTS
  Throttle Body snorcus 16 4,195 10-01-2006, 01:49 AM
Last Post: Drivesthebeast
  Throttle Body Tps Guide ZX3TUNR 0 1,176 08-21-2005, 08:59 AM
Last Post: ZX3TUNR
  Bbk Throttle Body Installed skifreak69 2 1,623 05-23-2005, 03:23 PM
Last Post: skifreak69
  Fc Throttle Body Install? SL8RZZX3 11 3,503 05-22-2004, 03:16 AM
Last Post: darkpuppet
